Showing results forย
Search instead forย
Did you mean:ย
Mounting 3 T301s on light-pole for 360 coverage.
Working on a project right now for a large outdoor WIFI deployment.  We will be mounting t301s units on light poles to create 360 coverage around the light poles.  I would like to mount the APs between 10-15ft high and all three at the same height around the pole.   I was told I need to keep the APs 3ft apart so should I mount the APs at 10ft - 13ft -16ft around the pole?   What is the proper mounting for t301s 360 coverage?
10 REPLIES 10
Esteemed Contributor II
As high as you can on the pole, 3 feet apart, and on different channels.
klaus_heidelber
If you use the linkage brackets provided with the T301s, there should be enough horizontal separation between the APs, no more vertical separation needed.
Remember to down-tilt 10-20 degrees depending on required coverage. See https://support.ruckuswireless.com/documents/528-t301s-access-point-mounting-guide/download for details.
Image_ images_messages_5f91c42a135b77e247998bbc_37295437cd9f04975d7c74f97f7efb14_RackMultipart20160727323015fee-8160f5e5-c587-4a15-baa7-669aaccc8c58-1146908774.jpg1469622930
Pole one is complete.
