LBS Disabled on wifi0 - Can't connect to vSPoT
michael_stone_7
I'm trying to get my 7372 APs to connect to our vSPoT instance via a ZoneDirector 1100.
We are running the latest firmware on the ZD and APs i.e. 9.10.0.0 build 218.
Everything looks configured correctly but I get the following on the ZD Monitor > Location Services.
Image_ images_messages_5f91c3e1135b77e2478c481d_4cbaf5dd386eb7cf36fa67bd79a110de_RackMultipart201506117081fryzi-6b3a1a02-a3b8-4291-ab6f-c4be4e7f5c3c-1294000332.JPG1433986826
So the ZD is connecting OK to the vSPoT but the APs are not connecting.
When I look at the individual APs, I can see the following.
rkscli: get lbs-server
State: Enabled
URL: 175.x.x.x
port: 8883
Venue: vspot
OK
rkscli: get lbs wlan0
LBS mode:
LBS Disabled on wifi0 OK
I can't find anything on the ZD configuration menue to enable LBS for a specific WLAN - it only enables per AP group.
Thanks,
Michael
7 REPLIES 7
sid_sok
Contributor II
Do you have wlan(s) on both radio?
Hi Sid,
There are two WLans at the moment which operate without restriction across the APs.
Thanks,
Michael
Mike..
Are the AP's connected to controller?
check --> ZD GUI --> Monitor.
APs are definitely connected to the ZD as I can login successfully. See Monitor > Access Points below and note that one of our APs is physically disconnected.
Image_ images_messages_5f91c474135b77e247a98bc2_0a8bafe2460a5ba12adae6617413a17a_RackMultipart201506124567wwgn8-d6f3e5f0-56fd-42de-934b-d682c3eb3894-794195901.JPG1434070380
Thanks,
Michael
