03-05-2023 05:11 PM
Hello Ruckus community!
I have a problem, I need to change the management IP of my Ruckus AP-R320 but I can't directly access its assigned IP locally, I can only configure some parameters via CLOUD, but on this Cloud platform, I can't find the option to change the IP or the AP settings.
Record:
1) at first if I entered by its factory ip locally, at that time I changed its IP to a static one to access it over the network.
2) I updated the firmware to the latest version available, and it was still managing it by the new local IP.
3) Then, I gave it an internet connection and registered the equipment and its license for cloud management.
4) A few minutes later, I could no longer access the AP locally, the page to enter the credentials loads but does not access when i send the credentials to login.
5) In the ruckus cloud platform, I access and the device is administratively active, but it does not allow me or I cannot find the option to change the previously assigned local IP.
It is not a problem with my browser, I tried with 3 different browsers and it does not access, it stays stuck on the credentials request page, it allows me to write them and hit the send button, but the page refreshes and nothing loads.
03-07-2023 12:42 AM
Once you do FD to the AP, in default state you can access and change IP as required but once it is managed by cloud controller you will need to open a support case and only a cloud engineer can help you to change it.
Best Regards
Vineet
03-05-2023 06:35 PM
Hi @MauC001
The AP admin password is auto generated and updated by the Cloud Controller. CLI/UI access to Ruckus Cloud-managed APs is not an option for end customers. The access is available to RUCKUS Support and Engineering for troubleshooting and resolving issues with specific APs. Please use any of below method to reach our support team who would assist you in making desired changes :
Best Regards
Vineet
03-06-2023 06:35 PM - edited 03-06-2023 06:38 PM
Hello! Thank you very much for your answer.
So, does that mean that I can't change the management IP that I assigned to an AP or from the Cloud console?
Maybe the only option is to factory restore it just to change its IP?
03-07-2023 12:15 AM
Hello @MauC001,
We would not recommend factory resetting the unit; however, reach out to us for any assistance wrt CLI access of Cloud managed APs by opening a case with us via https://support.ruckuswireless.com/contact-us
Hope this clarifies your query.
Vasanth Edward
03-07-2023 12:42 AM
Best Regards
Vineet
