02-03-2020 07:38 AM
07-03-2020 02:10 AM
07-03-2020 02:27 AM
07-03-2020 07:15 AM
Hi Bye,
There are total thee ways to downgrade vSZ.
1st: If a cluster backup was created during last
upgrade or before, then you can easily restore it and system will downgrade to previous
version with all the settings.
3rd: If no cluster or configuration backup available then downgrading vSZ will factory reset its configuration and you have to reconfigure it from the scratch.
IMPORTANT NOTE: All 3 ways required downtime as system will restart or reconfiguration will be required.
Syamanak Omer
07-03-2020 07:36 AM
07-03-2020 07:28 AM
