Enable mesh on t300?
thbert
I have a legacy Zonedirector with mostly 7762s and I recently obtained a t300. It successfully joined ZD and updated firmware but does not seem to have mesh enabled. According to this https://support.ruckuswireless.com/articles/000001673 the t300 should be able to mesh with 7762s. How do you enable mesh functionality on the t300? thanks
6 REPLIES 6
syamantakomer
Community Admin
Community Admin
Hi Treebert,
Could you confirm firmware version running on ZD?
Please refer below article. Though it refers a newer ZD version (10.X) but options are similar on older ZD versions (9.x) as well.
https://support.ruckuswireless.com/articles/000002193
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
thbert
I'm running ZD 9.8.3.0 build 58. The problem is that ZD says Mesh Mode is disabled on the t300 - how to enable it? No options for enabling it appear in the Configure > Access Point page in ZD for the AP as they do with the 7762s. thanks
Could you share a screenshot.
Syamantak Omer
Syamantak Omer
thbert
From ZD Monitor > Access Points
Image_ images_messages_5f91c44d135b77e247a10e06_3e5962068f581c44be063d050c2ba83c_RackMultipart20200618577361m3i-f6df81a6-e44f-4a39-9f90-2e9a95fdfc33-342374032.png1592495918
