Enable mesh on t300?
thbert
I have a legacy Zonedirector with mostly 7762s and I recently obtained a t300. It successfully joined ZD and updated firmware but does not seem to have mesh enabled. According to this https://support.ruckuswireless.com/articles/000001673 the t300 should be able to mesh with 7762s. How do you enable mesh functionality on the t300? thanks
6 REPLIES 6
syamantakomer
Community Admin
Community Admin
Hi Treebert,
Could you confirm firmware version running on ZD?
Please refer below article. Though it refers a newer ZD version (10.X) but options are similar on older ZD versions (9.x) as well.
https://support.ruckuswireless.com/articles/000002193
Syamantak Omer
Syamantak Omer
Sr.Staff TSE | CWNA | CCNA | RASZA | RICXI
RUCKUS Networks, CommScope!
Follow me on LinkedIn
thbert
I'm running ZD 9.8.3.0 build 58. The problem is that ZD says Mesh Mode is disabled on the t300 - how to enable it? No options for enabling it appear in the Configure > Access Point page in ZD for the AP as they do with the 7762s. thanks
Could you share a screenshot.
Syamantak Omer
Syamantak Omer
thbert
From ZD Monitor > Access Points
Image_ images_messages_5f91c44d135b77e247a10e06_3e5962068f581c44be063d050c2ba83c_RackMultipart20200618577361m3i-f6df81a6-e44f-4a39-9f90-2e9a95fdfc33-342374032.png1592495918
