AP goes offline after connecting to the Ruckus controller.
hugo_escobar_82
Brand new ap (R720) running firmware 5.2.0.0.1412 with static ip address.  I ssh to the ap and add the ip address to the controller and reboot.   It connects to the controller and then goes offline.  The ap is still pingable.  I ran the command get scg and I received the following output.
rkscli: get scg
------ SCG Information ------
SCG Service is enabled.
AP is managed by SCG.
State: CONN_GET_ADDR_STATE
Server List: 10.1.0.50,
No SSH tunnel exists
Failover List: Not found
Failover Max Retry: 2
DHCP Opt43 Code: 6
Server List from DHCP (Opt43/Opt52): Not found
SCG default URL: RuckusController
SCG config|heartbeat intervals: 30|30
SCG gwloss|serverloss timeouts: 1800|7200
Controller Cert Validation : disable
I have enough license available for the ap.  I have reset the ap various time and no luck.
4 REPLIES 4
syamantakomer
Community Admin
Community Admin
Hi Hugo,
I am not so sure but you might be hitting one known issue where AP with static IP could not establish SSH session with controller.
Quick workaround:
SSH into the AP and run below command.
        rkscli: set ipmode wan ipv4
        OK
To verify:
        rkscli: get ipmode wan
        IP Mode: ipv4
        OK
For permanent fix, please refer below article.
https://support.ruckuswireless.com/articles/000010443
Syamantak Omer
Syamantak Omer | Sr.Staff TSE | CWNA | CCNA | RASZA | RICXI
That worked! Thanks.
Great!
Good to know that it fixed the issue!].
hugo_escobar_82
