R7xx series in R6xx series mesh
ananth_rajagopa
Hi All,
We have an unleashed mesh with 3 R600's, we would like to add 2 more AP to this mesh. Should we go with R600 series itself or can we go for higher R700 series?
All are presently indoor and the the new once will also be installed indoors.
AR
1 ACCEPTED SOLUTION
sam_evans
You can not add R700 APs as they do not support Unleashed management. The R710 & R720 do though and will work with the R600 upto version 200.7
I would advise taking a look at the Mesh Best Practices Guide around tree depth and maximum hops as there are throughput and latency considerations to be made with this deployment type:
Image_ images_messages_6110f4df2ace6a75f0bb9cb3_5f4aa47ec10a87af0e3037ed11ab23b1_Mesh-086dd603-afda-4f2e-9b0a-27c91b84722b-409119032.png
Kind regards,
Sam
6 REPLIES 6
You are still able to extend the existing network, you can add the R600, R710, R720 AP models for example.
Here is a list of compatible AP models on Unleashed version 200.7:
Image_ images_messages_6111017202db9d546097e409_b813ed79dcbf51b7784054e7bbddeb6e_UnleshedSupportedAP-3e920844-0c49-4cc3-86a6-205588f02896-95880850.png
Thanks Sam!
