11-09-2020 11:07 AM
Hello, I've set up my first home network with nothing special regarding network rules, VLAN's, etc. The network seems to working great except the Wi-Fi seems to draining both my and my wife Pixel 3's. I've done a hard reset on my pixel and we've tested the Wi-Fi on different Wi-Fi networks and it seems the is coming from the R600 Unleashed AP. I actually have 3 of these AP's installed through the house, but deactivated the other 2 AP's to try and troubleshoot this issue. Any help would be greatly appreciated!
Network setup:
- pfSense 2.4.5-RELEASE-p1
- EdgeSwitch 24 250Wv1.9.1
11-10-2020 05:11 AM
Thanks, I disabled the threshold on WLAN0 do I need to disable it on the other WLAN's too?
11-10-2020 05:21 AM
You have only one WLAN "comet" and same is broadcasting on both the radio bands (2.4G and 5G).
Run the command for wlan32 as well.
11-10-2020 06:20 AM
Thanks for the help so far and I'll test it today. Does this setup look correct now?
ruckus(debug)# remote_ap_cli -A "get qos wlan0"
---- Command 'rkscli -c "get qos wlan0 "' executed at d4:68:
Ruckus Wireless SmartMedia QOS info for wlan0 interface
QOS Configuration options:
Classification: Enabled
UDP Heuristic Classification: Disabled
TOS Classification: Enabled
Dot1p Classification: Enabled
VID Voice Classification:
VID Video Classification:
VID BE Classification:
VID BK Classification:
Dot1p Classification VIDs:
Dot1p Marking VIDs:
Directed Multicast: Enabled
IGMP Snooping Mode: Enabled
MLD Snooping Mode: Disabled
Static TOS marking: Disabled (0x0)
Static Dot1p marking: Disabled (0x0)
General Mcast->U Cloned Filters TOS-Mark
Stats 3 3 0/0/0 0/0/0/0
L2 Mcast Packets Unicast Unk-Drop Known-Mcast
UDP Data 3 3 0 242
Heuristics Voice Video
UDP Packets 0 0
IGMP/MLD Clone1/2/3
Errors 0/0/0
No Filters are currently defined on wlan0 interface
OK
---- Command Execution Summary:
success: 1
failure: 0
total: 1
remote_ap_cli -A get qos wlan0
ruckus(debug)# remote_ap_cli -A "get qos wlan32"
---- Command 'rkscli -c "get qos wlan32 "' executed at d4:68:
Ruckus Wireless SmartMedia QOS info for wlan32 interface
Dot1p Marking VIDs:
Stats 0 0 0/0/0 0/0/0/0
UDP Data 0 0 0 920
UDP Packets 0 0
IGMP/MLD Clone1/2/3
Errors 0/0/0
No Filters are currently defined on wlan32 interface
OK
success: 1
failure: 0
total: 1
remote_ap_cli -A get qos wlan32
ruckus(debug)#
11-13-2020 12:04 PM
Looks fine.
Let us know if this improve things. If not, we can tweak more settings.
11-20-2020 08:50 AM
It looks like it improved, thank you for the assistance.
