Ok the Tegile controller A is LACP passive to TurboIron switch 1, ports 21 and 22, setup as link aggregation (in active mode).
The Tegile controller B is LACP passive to TurboIron switch 2, ports 21 and 22 as link aggregation (active).
So between the switches and the storage arrays, its configured up and operational.
Now, between TurboIron switch 1 and TurboIron switch 2, its configured as a static trunk on both ends. Because both ends are configured the same, the link is up.
I was just curious if there was any fundamental difference between creating a static trunk vs using the link aggregation commands. Obviously the link aggregation commands are required for the Tegile array since it speaks LACP. However between two switches, it sounds like to me you could configure it EITHER WAY, as long as both ends are configured the same.
There's no bandwidth difference between either way right? As long as both ends are the same, either solution accomplishes the same result correct?
