what is this problem ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-09-2018 08:53 AM
Feb 8 08:44:03 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb 8 08:44:03 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb 8 08:44:03 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:459
Feb 8 08:44:03 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
Feb 8 08:44:05 RuckusAP daemon.info hub_registrar: OCSP: 'unknown' on ap-registrar.ruckuswireless.com - withhold query
Feb 8 08:44:08 RuckusAP daemon.err wsgclient[464]: crSocketConn:56 errno:103/Software caused connection abort
Feb 8 08:44:08 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb 8 08:44:08 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb 8 08:44:08 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:460
Feb 8 08:44:08 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
Feb 8 08:44:13 RuckusAP daemon.err wsgclient[464]: crSocketConn:56 errno:103/Software caused connection abort
Feb 8 08:44:13 RuckusAP daemon.err wsgclient[464]: crSocketInit:243 crSocketConn failed ret = 124
Feb 8 08:44:13 RuckusAP daemon.err wsgclient[464]: cmrInit:138 Call 'crDefSocketInit()' failed, ip:10.1.115.16 port:443, ret:124/CR initial socket failed
Feb 8 08:44:13 RuckusAP daemon.err wsgclient[464]: communicatorInit:364 Init connection failed, ret:124, connectRetry:461
Feb 8 08:44:13 RuckusAP daemon.err wsgclient[464]: registration:594 Failed to init socket! ret:124 url:https://10.1.115.16/wsg/ap
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2018 07:01 AM
i did it , but not work 😞
virtual smart zone block port 443 , i not use firewall
ap directli connect virtual machine
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 02:06 AM
any solution for the above ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 02:12 AM
i can not join ap on Virtual smart zone (high Scale)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 02:54 AM
when i on Tunnel WLAN traffic through Ruckus GRE , clint not get ip address
no used nat , not used firewall
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 11:02 PM
I had the same issue today. the correct resolution was to disable the ap cert check on the sz controller using the command above 'no ap-cert-check'. You need CLI access to the controller and log in to privileged mode to execute the command.
Some more detail is available here with this workaround and the fix:
https://support.ruckuswireless.com/answers/000005390?_ga=2.129584140.1025065841.1523453190-121888804...
cheers
cheers
