vSZ webUI unavailable (rel 3.4.2)
rick_macchio
I tried installing a single controller running 3.4.2 via .ova and the setup went smoothly until I got to the point where I tried connecting on port 8443. The controller is reachable via SSH and otherwise appears to be fine. I've noticed that I can't seem to turn on the web service but there are not errors explaining why.
Welcome to the Ruckus Virtual SmartZone - Essentials Command Line Interface
Version: 3.4.2.0.152
new-host-3> en
Password: *********
new-host-3# show service
No. Application Name Health Status Log Level # of Logs
1 API Offline 0
2 CNR Online 1
3 CaptivePortal Online 6
4 Cassandra Offline 4
5 Configurer Online 6
6 Core Offline 6
7 EAut Online 2
8 ElasticSearch Online 4
9 LogMgr Online 2
10 MdProxy Online 1
11 MemProxy Online 1
12 Memcached Online 1
13 Mosquitto Online 1
14 MsgDist Online 1
15 NC Online 1
16 NginX Online 3
17 Observer Online 1
18 OnlineSignup Offline 1
19 RadiusProxy Offline 0
20 SCIAgent Online 2
21 SNMP Online 1
22 SessMgr Online 1
23 SubscriberManagement Offline 2
24 SubscriberPortal Offline 2
25 Web Offline 4
new-host-3# service start
Please note that this command will cause current SSH connection closed for SSH restart. Do you want to start all services (or input 'no' to cancel)? [yes/no] yes
Starting all services...
Process had been started before and running...
System already startup, skip startup process...
Successful operation
1 API Offline 0
2 CNR Online 1
6 Core Offline 6
7 EAut Online 2
9 LogMgr Online 2
10 MdProxy Online 1
14 MsgDist Online 1
15 NC Online 1
16 NginX Online 3
21 SNMP Online 1
22 SessMgr Online 1
25 Web Offline 4
new-host-3# show mem
MemTotal: 15432828 kB
MemFree: 192352 kB
Buffers: 9196 kB
Cached: 259852 kB
SwapCached: 0 kB
I haven't plugged in any APs yet. Just wanted to get this part running first. Any help would be appreciated.
16 REPLIES 16
rafael_rocha_i5
Hey friends, did you guys are able to figure it out ? If so, what is the solution this behavior ?
tien_phan_anotw
Contributor
does anyone fix this issue? I am having the same issue and trying to find how to fix it.
Thank you.
tien_phan_anotw
Contributor
In my case, I rebooted the vSZ. And could not access WebUI.
vSZ-E-1# show service
   1     AP Diagnostic Informati                                0
         on
   2     Cassandra                Online                        5
   3     Ccmd                     Offline          WARN         1
   4     Collectd                 Offline                       0
   5     Communicator             Offline          WARN         12
   6     Configurer               Online           WARN         14
   7     Core                     Offline          WARN         17
   8     DBlade                                                 0
   9     Diagnostics                                            0
   10    EAut                     Offline          WARN         2
   11    ElasticSearch            Online                        3
   12    FIPS                                                   0
   13    LogMgr                   Online           WARN         2
   14    MdProxy                  Online           WARN         1
   15    MemProxy                 Offline          WARN         1
   16    Memcached                Online                        1
   17    Mosquitto                Online                        1
   18    MsgDist                  Online           WARN         1
   19    NC                       Offline          WARN         1
   20    NginX                    Online                        3
   21    Observer                 Online           WARN         1
   22    RadiusProxy              Offline          WARN         1
   23    SNMP                     Offline          WARN         1
   24    ScgUniversalExporter     Offline          WARN         4
   25    SessMgr                  Online           WARN         1
   26    SubscriberManagement     Offline          WARN         12
   27    SubscriberPortal         Offline          WARN         2
   28    Switchm                  Offline          WARN         12
   29    System                                                 11
   30    Web                      Offline          WARN         12
vSZ-E-1#
then try to start services again
vSZ-E-1# service start
configurer already startup, skip startup process...
but nothing changes
Anusha_Vemula
Community Manager
Community Manager
Hi Tien,
Since the web service is offline, you will not get the GUI access.
Once 'service restart' is performed, you need to wait for 30 to 45 mins for all the services to come online.
- Anusha
tien_phan_anotw
Contributor
hi Anusha,
Sure, it took around 20 to 30 minutes for all services are up. Now it is working fine.
Also I see the tag besides controller name `Flagged`. May be I need to increase the number of CPU. Now I spend 4 CPU cores for vSZ-E.
