05-11-2023 04:05 AM
Hello
We have 2 vSZ-H controllers deployed (not clustered), secondary was only built temporarily to accomodate new client. We now want to migrate 200 access points from temporary vSZ02 controller onto our production vSZ01.
What would be the easiest way to achieve this with minimal downtime and minimal manual (AP CLI) job?
05-11-2023 04:35 AM
Understood. Please try the following.
05-11-2023 04:14 AM
We have am option called switch Cluster on vSZ. This could be used to move APs from one Cluster to another.
What is the current firmware version on the primary and backup controllers ?
05-11-2023 04:25 AM
James
Controllers are not clustered and running different versions of firmware (6.0 & 6.1)z
05-11-2023 04:35 AM
05-11-2023 07:50 AM
Hi James
This worked perfectly, what a brilliant feature!
Thank you so much for you assistance.
