Showing results forย
Search instead forย
Did you mean:ย
could not set up virtual smart zone on Virtual Box by importing ova file
hello everybody,
first of all, I show you what I did setup.
ISO file: vscg-5.1.0.0.496.ova
VM: Virtual Box version 5.2.28 r130011 (Qt5.6.3)
RAM: 5G
CPU: 2 cores.
Network Interface: keep only one NIC [Attached to Bridged Adapter, Name en0: Wi-Fi (AirPort)]
I start this VM, then see the error:
Bringing up interface bond: Device eth* does not seem to be present, delaying initialization.
Bringing up interface ifcfg-eth*: Device eth* does not seem to be present, delaying initialization.
[FAILED]
Bringing up interface br:
Determining IP information for br..."up" is invalid lladdr.
then the login terminar appears, I can login with admin and password, then enable to setup. I choose both of manual & dynamic, but they could not get the IP Address. I see they are related to the error on booting screen. But, I don't know any command to fix it for now on vSZ operating system.
Could you please help me?
Thank you so much!
Image_ images_messages_5f91c3f4135b77e2478f9221_73d8a9f9521624ad99f26185943cf8a6_RackMultipart20190513928881rvy-e5e6cffa-25de-4af3-bb71-cf2dfdf25945-1497956295.png1557745857Image_ images_messages_5f91c3f4135b77e2478f9221_20aee4508c35f241daa5fd3f899df463_RackMultipart2019051336780zs1s-75785d16-dc34-4559-a249-df80e6aaccef-1283728481.png1557745869Image_ images_messages_5f91c3f4135b77e2478f9221_ec6f00b1467003ffd9affdaea9061862_RackMultipart20190513774113u1d-f2f3913b-bbf6-4b62-ab25-d25ef31f6d5a-401234554.png1557745898
8 REPLIES 8
thanks a lot Ankush and Diego Garcia del Rio. You saved my life !
unfortunately, my vSZ VM could not start after finished the configuration on web interface. Although it informs that I can login to https://10.10.1.224/...
based on current system configuration, I set 5G ram and is that root cause? the vSZ Essential didn't have enough resource to work?
please let me know what should I do? thank you so much bro!
You need at least 13G of ram. Open a Google account and get their Google cloud credit and deploy vsz there for one month for free. Or find a bigger server locally
I got it. Thank you so much Diego!
