VSZ - Essential 3.6.1.0.227
mohamed_sayad
We are using VSZ - Essential 3.6.1.0.227 and about a week ago it is no longer showing the correct details of the access points, mesh role of external APs T310D is showing as Disabled instead of RAP for hardwired and MAP for meshed APs, although the role is enabled and set to automatic meshing. The second thing, it does not show the total of connected client devices, it shows Zero, although devices are connected and able to surf the internet.
The access points firmware version is 3.6.1.0.354.
1 ACCEPTED SOLUTION
Hi Ambika,
The problem was with some security ports we closed, we had to whitelist them with some static IPs. Now, everything is back to normal.
thank you.
4 REPLIES 4
Ambika-leimapok
Hi Mohamed,
  • Could you please confirm if you have tried in different browser?
  • Is the issue seen in all the APs ?
Leimapokpam Ambika
Sr.Technical Support Engineer
CWNA | RASZA | RACPA
mohamed_sayad
Hi Ambika,
Yes I already tired in another browser, the same issue, it is not a browser related issue:
Yes, the issue is seen il all 68 APs.
Hi Mohamed,
Please execute the below commands on controller CLI
vSZ# debug
vSZ(debug)# reindex-elasticsearch-all
Start to reindex ElasticSearch, may need few minutes...
Successful operation
Leimapokpam Ambika
Hi Ambika,
thank you.
