11-06-2024 08:09 AM
I am attempting to upgrade a SZ144 controller to the latest stable release announced by Ruckus for this product which is SmartZone 6.1.2 (LT-GD Patch 3)
My question is that if i can directly upgrade to 6.1.2 LT-GD Patch 3 from 6.1.2 LT-GD directly without having to upgrade to 6.1.2 Patch 1 and 6.1.2 Patch 2
The controller is currently on this release
Controller Version: 6.1.2.0.354
• Control Plane Software Version: 6.1.2.0.187
• Data Plane Software Version: 6.1.2.0.19
• AP Firmware Version:6.1.2.0.850
The target release is
• Controller Version: 6.1.2.0.487
• Control Plane Software Version: 6.1.2.0.253
• Data Plane Software Version: 6.1.2.0.30
• AP Firmware Version:6.1.2.0.2104
11-06-2024 08:19 AM
Hi @Ahmed_Youssef, yes, it will be a direct upgrade from 6.1.2.0.354 to 6.1.2.0.487.
11-06-2024 08:31 AM
Many thanks Edward for your reply.
If you allow me to ask another question. should I apply "SmartZone 6.1.2 (LT-GD) Sigpack 1.650.0" after or before the software upgrade.
11-06-2024 09:06 AM
Since SZ is already in version 6.1.2, the sequence does not significantly impact the outcome.
