08-30-2021 11:44 AM
Hi fellows, my environment in question is about one smartzone 6.0.0.0.1331 and 100 managed icx switches.
To the point. I am try to see when a port of the switches goes in the ERR-Disable state due of the bpdu protect acting up. In the smartzone network -> switches -> anyswitch -> Ports / Port Details, there still no column about ''state'' as in the show int brief, no the status column do not reflect blocked/learning or err-disable state information, of the port. Looking at the events or alarm of the eer-disable log not shows too. So I tried to create a custom event - Events -> Switch Custom Events. Like this
This alarm/event is not triggering too. Any idea why and how can I fixed it ?
Regards.
09-13-2021 02:03 PM
Hi Rafael,
Please open a case with Ruckus support and report the issue.
A fix is available for this issue. Update the case number here so that I can follow up.
