02-24-2025 11:09 PM
Hi All,
I am trying to replace my access point to H550.
But I found that H550 not support in version 5.2.2.
So I would you like to know can i upload AP patch version 6.1.2 to SZ144 instead of upgrade SZ144?
Best regars,
Tom
04-28-2025 07:41 AM
Hi Tom,
Thank you for contacting RUCKUS Support via the Community Forum.
Please be informed that the AP patch for version 6.1.2 cannot be applied to a SmartZone 144 (SZ144) running version 5.2.2, as it is a lower version than 6.1.2.
You will need to first upgrade the SZ144 to version 6.1.2 and then apply the AP patch.
Did I answer your query? If yes, hit the Kudos button and also accept the answer as
Accepted solution.
