Setting up GBT/MQTT. Looking for Subscriber Software, based on your Getting Started documentation.
suny_iskandar_a
Based on https://support.ruckuswireless.com/documents/1520-smartzone-3-5-ga-getting-started-on-gpb-mqtt document (Page 7), there is a link to Subscriber Software which is then bring me to another site jira-wiki.ruckuswireless.com which I do not have access to. Can anyone kindly show me the way how to download the software. Thank You.
5 REPLIES 5
martin_martin
Valued Contributor
Hi Suny
I will ask the support portal team to make the file available via a different site.
Kind regards
Martin
Esteemed Contributor II
Hi Suny,
   I have posted the GPB / MQTT test subscriber software on our Support site:
https://support.ruckuswireless.com/software/2076-smartzone-gpb-mqtt-interface-test-subscriber-softwa...
Thank you Michael
vinicius_caetan
Hi
How can i get the file on confluence?
