12-15-2021 05:55 AM
I'm running a pair of SZ124s on v5.2.2.0.1161 and recently clustered them. Clicked the "rebalance APs" button and now I see an even split of ~200 assigned to each of the two SZs.... but, when checking the AP page and enabling the Data Plane column, only 3 APs are using one of the controllers' data plane while all the others are locked on the second SZ. Doesn't seem very balanced to me, is this "expected behaviour"?
12-15-2021 06:05 AM
Hi @Greg_WiGuy
Can you try a couple more time to rebalance and also please check below article that gives better understanding on "rebalancing AP's" behavior.
https://support.ruckuswireless.com/articles/000005814
Best Regards
Vineet
12-15-2021 12:29 PM
Thanks Vineet, I understand it a little better thanks to the article you posted.
I've tried rebalancing a couple times today but still only 4/400 APs using one of the dataplanes while the control plane seems pretty well balanced.
12-15-2021 07:26 PM
Can you please get the "get scg" command output from few of the AP's to check if they have all DP's IP list ?
Best Regards
Vineet
12-16-2021 06:02 AM
The 'get scg' command lists both SZ IP addresses next to "Server List:" and "SSH Tunnel Connected to:" the IP of the SZ that is listed under control plane.
I couldnt see anything that called out the Data Plane specifically.
