SCG200 - How can I block traffic through DataPlane SCG-D1
How can I block traffic by Data Plane1
Friends,
We are working with SCG200, and have set up a new Datapla. I would like to know how do I block DP-0 traffic, forcing the new Data plane (DP-1) to take over?
I've tried ACL without success.
I have already tried via the command line, both in the AP, and in the CLI of the SCG, also to no avail.
CLI-AP:
set tunnelmgr : set tunnelmgr {options}
                 -> disable/enable
                 -> tunnel
                 -> type [mode comcast]
                 -> auth
                 -> port
ü  rkscli: set tunnelmgr SCG-D Sorry, no match to set tunnelmgr SCG-D found
 ü  rkscli: set tunnelmgr SCG-D 1Sorry, no match to set tunnelmgr SCG-D 1 found
 ARC-RJ-WLC-R08# remote ap-cli D4:68:4D:10:11:00 "set tunnelmgr port SCG-D0 disable"
Error: parameter error -- Agrument must be digits
 ARC-RJ-WLC-R08# remote ap-cli D4:68:4D:10:11:00 "set tunnelmgr SCG-D0 disable"
 ARC-RJ-WLC-R08# remote ap-cli D4:68:4D:10:11:00 "set tunnelmgr port SCG-D0 port disable"
Any tips?
"get tunnelmgr"
------ TUNNELMGR Information ------
tunnelmgr Service:      Enabled
Tunnel Establishment:   Enabled
Tunnel Authentication:  Enabled
Tunnel Cipher:          Disabled
PMTU Discovery:         Enabled
Node Affinity:          Disabled
Force Fragmentation:    Disabled
Tunnel Type: Ruckus-GRE
SCG-D IP List:       =1@[x.x.x.x]:23233,[y.y.y.y]:23233
Internal Subnet:        10.x.0.0
GRE over UDP: AP/SCG-D UDP port # 23233/23233
Keep Alive Interval/Retry-limit: 10/6
Keep Alive Interval2: N/A
4 REPLIES 4
Hello.
I am not sure about SCG but in vSZ you can use the feature called vDP Zone Affinity. You will be able to create a list w/ Data planes and attach them to specific AP Zone.
Hello Genrikh,
Thanks for the quick response.
I saw it, I searched it here in support Ruckus, but this feature is only working on vSZ.
http://docs.ruckuswireless.com/smartzone/3.6.1/sz100-vsze-administrator-guide/GUID-508F58A7-0642-4F2...
Thanks!
Gentlemen,
Sorted out.
I configured an extended ACL on my router, blocking the IP of the DTP0.
Then when I ran the "get tunnelmgr" command, and the failover worked, that is, I could only see the traffic / tunnel of the new dataplane
Hello.
You can use ACL on AP to do the same. It will work.
#AP CLI script
#define Zone's AP FW version
fw_version=3.2.1.0.682
#define Model class, only all is supported now.
model=all
#CLI commands
set qos eth0 ip add ucast src  192.168.100.105/255.255.255.255 drop
