Ruckus Virtual SmartZone on Nutanix AHV
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-02-2018 06:00 PM
Is Virtual SmartZone supported to run on Nutanix AHV clusters? Can't seem to find any information about it and haven't heard of anyone who's tried it. Since AHV is based on KVM, it should technically work.
I just need confirmation that it's supported. Some documentation would be much appreciated too. We're planning to migrate from ZD in a few months time.
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2018 07:37 AM
Hi.
No, it's not supported.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2018 08:52 AM
I'm sure it works, but if support ever asks you, just say it's running on VMware. They wouldn't know the difference.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-17-2019 04:25 PM
Hi, is there an update on this? we are also about to move the vSZ from VMware to Nutanix.
Isn't it that, as long as the underlying network setup is the same to Nutanix, it should work?
Need your input. Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-17-2019 06:00 PM
We've successfully deployed VSZ on Nutanix AHV a couple of months ago. Two VSZ nodes installed on separate AHV clusters, on two different sites.
We just used the KVM image. Everything else was pretty straightforward.
