02-10-2025 11:42 PM
Hi, I have a new T670 AP here, which is connected via PoE 802.3.at, unfortunately it does not connect to vSZ. vSZ is installed in version 7.0.0.1026. I also have other R560s that connect without any problems. AP Patch 6 is also installed. The AP is connected via the PoE port and flashes yellow. Is there anything else I have overlooked? What else is missing?
Thanks Tom
02-13-2025 10:04 AM
Hello Tom,
Do you have SSH access to the impacted T670 AP?
If Yes, you can share the output for the following commands:
get version
get scg
get power-mode
get rpki-cert issuer
I am looking forward to your response.
Vignesh
02-18-2025 02:23 AM
Hi Vignesh,
thanks a lot. my problem is solved. the solution was that after updating the vSZ to 7.0.0 I had not configured a scheduled firmware upgrade for the default zone. I assumed that I would first see the APs and then be able to update them. I didn't expect the T670s to be visible until the firmware update. It also explains why I could no longer log on to the APs directly.
Thank you very much
Regards Tom
