02-05-2025 10:58 PM
What is the minimum vSZ firmware version that is required for the compatibility of R350e Wi-Fi AP?
02-07-2025 08:05 AM
The R350 is compatible starting from SmartZone 6.1.2. You can check the AP compatibility list in the following guide:
SmartZone 6.1.2 (LT-GD) Upgrade Guide | Technical Documents | Ruckus Wireless Support
However, the R350e is compatible with SmartZone 7.0, as per the upgrade guide. Please refer to the 7.0 upgrade guide for more details:
RUCKUS SmartZone (ST-GA) Upgrade Guide, 7.0.0 | Technical Documents | Ruckus Wireless Support
It looks like you are planning to upgrade the controller. Could you confirm the current version of your controller? Also, what AP models have you deployed?
Note: If you are upgrading the controller, I recommend upgrading to 7.1.0, as it is the latest stable release. However, we need to know your current controller version to provide the appropriate next steps.
Let me know if you have any further questions.
Vignesh Ramasamy
Sr Technical Support Engineer || CWNA
Work hours: Monday - Friday 9:00 AM to 5:00 PM PST
02-07-2025 08:05 AM
Vignesh Ramasamy
