Multiple issues with wifi7 client on SZ firmware
kessvn
I have a test setup with one R770 running on the latest 7.0 vSZ firmware.
Wifi 6e devices are running without any issues but there are some issues with wifi7 client, motorola razr 50 ultra (do not have any other wifi7 clients at the moment):
1. It connects only on 2.4 ghz band
2. Sometimes it tries to connect to 5 or 6ghz bands but it fails
3. Disabling 2.4ghz radio makes it connect to 5+6ghz (while using MLO). In this case I am getting about 200mbs download and 800mbps upload speeds. Noticed that data transfers are running only on 5ghz band even sz shows that client is connected on both bands. Tried to disable MLO - no improvementa in throughput.
4. Installed unleashed software on another R770 AP and client connects to 6ghz radio. Speedtest shows about 2.8gbps download and 1.8gbps upload. MLO does not work - maybe unleashed software does not support it at the moment.
Has anyone faced any similar isues with SmartZone firmware?
0 REPLIES 0
