07-29-2025 12:43 AM
Hello everyone,
We’re in the process of migrating from a SmartZone 100 (running version 3.5.1.0.862) to a vSZ-E deployment. Our goal is to support both legacy Wi-Fi 6 access points (H500, R500, R510, R600, R700, T300, R350, R550) and new Wi-Fi 7 APs (R770).
We're facing some challenges and would appreciate insights from those who have handled similar migrations. Specifically, we’re looking for the best approach to migrate or re-deploy the environment while keeping all APs operational and minimizing downtime.
Would you recommend:
Upgrading the existing controller and doing a full backup/restore into vSZ?
Starting fresh with a new vSZ deployment and migrating APs zone by zone?
Any specific firmware path or version to ensure compatibility with both AP generations?
Thanks in advance for your guidance!
07-30-2025 04:29 PM - edited 07-30-2025 04:35 PM
Leimapokpam Ambika has a good answer, IF you really want to support only WiFi 6 and WiFi 7 APs. If this is the case though, then I'd personally just directly install the latest 7.0 or 7.1 release, then add a 6.1.2 AP Patch. Much quicker.
But several APs you list are very old WiFi 5 APs.
There is no release of SmartZone which supports both the R770 and also H500/R500/R600/R700/T300. I have a tool here which lets you play around with AP combinations.
If you must run R770 APs plus old WiFi 5 APs then Ruckus One supports most of your list (except H500 & R700).
Or you can leave your old WiFi 5 APs on the SZ100 and put the WiFi 6/7 APs on a fresh vSZ. Then decommission the SZ100 once all your old APs are updated. The downside is that the vSZ and SZ100 will need to be managed independently.
07-30-2025 09:22 AM
Hi Adam,
Restoring the backup taken from SZ-100 to vSZ is not possible due to the platform difference
Hence, you would need to configure the new controller (vSZ-E) from the scratch.
To have the legacy APs working in the new vSZ-E follow the below steps:
07-31-2025 03:05 AM
Hi Leimapokpam,
Thank you for your answer. Can't I create 3 Zones for every APs ( Legacy, Wifi6, Wifi7) and follow your suggested deployment ?
07-31-2025 03:10 AM
Thanks ms for your answer, Actually, I am changing all old APs except the H500 with 3.5.1.0.1010 firmware. Is there any chance to create a legacy zone for this Model? Thanks
