02-16-2022 01:30 AM
I try to manage an ICX Switch (SPS08095d) over the vSZ 5.2.2.
To do that I deleted the startup config and reloaded the switch. After that I set the IP address and the manager in the CLI. The switch then connects to the vSZ and is moved to the goup. The defined user is set and the VLANs are configured to the switch. But if I try to change VLAN on the ports via vSZ the change does not take affect.
Regardles to this I did not find any information to the following question:
How can I change options persistant on the switch which are not configurable in the vSZ?
Thank you for your help.
Johannes
04-05-2022 07:18 AM
After an Update of the SmartZone to 6.1 it is working. Got no Cloue why it was not working before.
04-06-2022 01:28 PM
Hi there,
Glad to know it is working post upgrade.
It is hard to confirm without checking the logs from controller and switch, this is why I suggested to report the issue to Ruckus support.
