10-28-2022 12:50 AM
Hi;
I'm new in Ruckus Devices. I have Smart Zone Controller having the VIRTUAL SMARTZONE - HIGH SCALE Software on that. I want to use the IoT Controller Suite NODE RED Option to get the devices information on my webserver.
How can I use the IoT Controller Suite Node Red Option? Do I have to update the software somewhere or connect some device with the SmartZone controller?
Please Guide.
Regards
Laeeq
11-01-2022 07:57 AM
Hi @laeeq2410
You can use SNMP. It can be configured from the controller System settings. The MIB file can be downloaded for 5.1 from our support site.
Phiravin
11-01-2022 08:12 AM
HI Phiravin;
Thank you for the answer. So to use the SNMP is it necessary to buy and use zone director or i can do this with my vSZ 5.1.
Regards
Laeeq
11-01-2022 09:08 AM
Hi @laeeq2410
You can configure SNMPv2 or SNMPv3 in vSZ. Please refer to the links below.
vSZ-E Admin Guide (5.1):
vSZ-E SNMP Reference Guide (5.1)
https://support.ruckuswireless.com/documents/2542-smartzone-5-1-ga-snmp-mib-reference-sz100-vsz-e
Phiravin
