I have zones using IPv6 for AP management but wanted to create AAA using IPV4. I am however not able to as it is only requesting for an IPV6 address. Is there a work around to this? It is extremely important to have the AAA working on IPV4 for external analytics and captive portal functionality.
Hi Anthony, Assuming you have a vSZ-H, you need to have enabled both IPv4 and IPv6 in the initial startup wizard. If you have both protocols enabled, you can have IPv6 AP Mgt, and IPv4 AAA servers (should be an option).
Firstly you need to check the manual guide because our main solution is under guidebook,if there was no helps for you then you can contact QuickBooks help, they provide the errorless solution for all.I am getting help from them,
