07-20-2022 08:35 AM
Hi Guys,
Can you please help me to identify the following two event codes for disconnected client:
"disconnectReason"="7"
"disconnectReason"="8"
Thanks in advance
Janko
07-20-2022 09:55 AM
Hi @JFourie,
Here are explanation on the requested disconnect reason codes:
DisconnectReason = 7
Deauthentication frame with reason code 7. This radio is informing the other radio to deauth because there isn't an association. It's likely a client is sending an access point frames while not having an association with this access point.
DisconnectReason = 8
The sending UE/client is leaving/left the BSS voluntarily.
Hope this helps.
Vasanth Edward
04-11-2024 10:08 AM
Hi, I have an Apple Tv device (wich mean it doesn´t move at all) and I receiving DisconnectReason = 8 many times daily.
Thanks in advance.
