01-25-2022 01:01 AM
We are trying to integrate Ruckus SZ controller with our guest wifi system, We need to set NbiIP parameter in redirection url as our public IP instead of local management IP. By default this parameter is local management ip of SZ controller.
Here is redirection URL :
login?nbiIP=192.168.8.97&client_mac=ENCd3c2aef98889a86001b5aa0d66e7f8fc2f95d0f6f7ececba&domain_name=Gebze&reason=Un-Auth-Captive&wlanName=ruckusDevelopment&dn=scg.ruckuswireless.com&ssid=ruckusDevelopment&mac=c8:03:f5:39:01:40&url=https%3A%2F%2Fdeneme.com%2F&proxy=0&vlan=1&wlan=2&sip=scg.ruckuswireless.com&zoneName=sEjfBX2-ihl1grlttAtdqR9iZV8ZyAi_bnfl6wtCxH0_1643096951069&apip=192.168.10.201&sshTunnelStatus=1&uip=ENCb2579826807a64302892e68ff98dd8ab HTTP/1.1
Is it possible to define a custom northbound interface IP ? If not, can we attach the public IP to the URL somehow ?
Thank you.
01-25-2022 03:01 AM
We figured it out. The solution is : Under System > Cluster, configure control planes, We have set the "Control NAT IP" as the public IP in the Physical interfaces tab.
Then NbiIP parameter becomes the public IP.
Thank you for your attention. @toomas_kadarpik , @parikshith_nagaraj_aa0004
01-25-2022 03:13 AM
@ali_talha_cevik yes, that is correct. Redirection NBI would be public IP in that case.
Parikshith
