Sorry for the comment. Didn't mean it as a something obvious. . I had issues where the default gateway was configured but the route wasn't active in the ap. Is the IP range the same when using static or dhcp ? Smartzone uses an internal pool of ips to setup ssh tunneling between the ap and the controller. That range didn't use to be configurable and that range also couldn't be used on the APs themselves or on any other IP destination that smartzone would have to reach. On the latest versions the range is configurable. Any chance it might be using ips in the range 10.254.0.0/16 or 10.255.0.0/16?
More details here.
https://forums.ruckuswireless.com/ruc...
Also, looking at the log, was the IP manually assigned ip 10.10.99.255? .. I imagine that there could be a code path on the ap checking that the IP doesn't end in 255 which would be valid as long as you're using masks in the /1-23 range. (meaning the check would be wrong).
Mar 12 01:46:51 RuckusAP local2.err syslog: AP get the broadcast ip in its subnet, the broadcast ip is 10.10.99.255
Or is it happening with any static IP?
I didn't notice your long post history jerónimo. Once again sorry of the first comment sounded wrong.
