08-12-2025 07:20 AM
Hello there,
we have a bigger setup with 436 Access Points. These are controlled with two SZ-124 in a cluster. It's running on version 5.2.2.0.317. The following Access Points are in use: R500, R510, R550, T300 and T750.
We would deploy the vSZ instances on 6.1.12, since 5.2.2 is End-of-maintenance. This is the first issue, because the R500 and T300 models aren't supported in 6.1.12 - only with 5.2.2 AP patch. Also, some zones are mixed with supported and unsupported AP's My idea is this:
Do you know if this will work or do you have any suggestions?
Thanks in Advance!
