Adding Zones via a script in smartcell gateway 200
quintin_schnuir
I am new to this and need help please. can multi zones be added via a script ? if so please can you please help and direct me how ?
thanx
2 REPLIES 2
abilash_p_r
Contributor
Hi Quintin,
Do you need a script to create multi zone via script ?
If it is yes, are you looking to run this on linux or windows pc ? or you want to run it on vSZ using AP-CLI Script ?
Abilash PR.
quintin_schnuir
Hi Abilash
 thanx for your reply.  I have 500 zone's to create,  so creating a script to loaded all the new zones would be so much more efficient. I am not sure which will be easier , from windows or a AP-cli.... is it possible to explain to me step by step on how to do this please ?
thanx
