โ05-21-2023 04:24 PM
We are using a VSZ, we noticed that when the controller reaches 100% of CPU, ALL APs drop (about 60 APs), then start reconnecting slowly (and keep dropping from time to time). We didn't have any issues on firmware version 5, and no changes in the network has been made, but once we upgraded to 6.1, this started happening. We have drastically increased the resources in the VM, they are more than enough and more than the minimum requirement.
We are really struggling with this.
โ05-23-2023 02:47 AM
Hi @Luis
The Heartbeat loss event is generated after the AP is offline or when there is no communication from the for certain Hello packets.
But it does certainly look like a communication issue since the vSZ is going 100% CPU and not responding to APs.
Any update on the below information:
vSZ-E or vSZ-H?
Number of APs connected: Online and Offline
Number of Switches connected : Online and Offline
HDD
CPU
RAM
Are there are components set to "Debug" under Monitor >> Application Logs ?
โ05-23-2023 03:01 PM
Hi there Sanjay,
โ05-23-2023 06:58 PM
Hi @Luis
The configuration looks fine. Plase open a support case and look at the logs and see what is causing the issue.
โ05-24-2023 03:19 PM
Thank you Sanjay,
We decided to downgrade to 5.2.2. Now the CPU only peaks at 67%. No AP drops.
We'll stay here until this is fixed in further firmware versions.
Thank you for your help.
โ05-24-2023 07:58 PM
Hi @Luis
Sure, let us know if you face any issues.
