ACCESS POINT REGISTERED IN VSZ BUT NOT LISTED
municipio_porti
Hello
I have an access point that, despite being registered with the controller and in the number of access points connected, does not appear on the access points menu.
I can ping but can't login in ssh with the default super user or with the login configured in vSZ.
4 REPLIES 4
eightohtwoeleve
Contributor III
Have you disconnected and reconnected it? Remote, well, did you disable PoE on the port and re-enable? I've had AP just sort of hang and the only solution is to reboot them.
municipio_porti
resolved with
controller(debug)# reindex-elasticsearch-all
Thanks! How did you find that?
