802.1X Virtual Smart Zone using NPS with Error Code:66
stephen_johanns
We have our 802.1x RADIUS Server configured to use an NPS Server.
When we test the RADIUS Server from the Smart Zone Controller or via an 802.11x enabled SSID it fails.
In the logs on the NPS Server we see
Error Code: 66
Reason Code: The user attempted to use an authentication method that is not enabled on the matching network policy
Image_ images_messages_5f91c403135b77e247919cac_5673b2e8c6b65077c302b0ff6327f88e_RackMultipart20200924571447ios-a5e447fd-a1a3-4e56-b568-271b1055fa6a-1589087405.png1600946923
9 REPLIES 9
Hi Stephen,
Could you select EAP Types and make sure correct certificate is mapped?
Image_ images_messages_5f91c48c135b77e247ae0a21_aa4c0e039503d3ff4fa3fc7ce06bee5f_RackMultipart2020092430026bir5-e9542233-f905-468a-9f94-63163f0a3dac-1525658677.png1600973903
Also enable "Wireless Other" in NAS Port type.
Image_ images_messages_5f91c48c135b77e247ae0a21_cd5eecfaf7b87c8f4838e7b576bd936c_RackMultipart2020092479892i1lo-f6a3e853-3f9f-40bf-bdde-9f1b365c9c6e-2067588036.png1600973833
Post making above changes if you are still facing issues, please open a support case and they will assist you.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
PEAP Cert Details:
Image_ images_messages_5f91c48d135b77e247ae3d6a_ed1d63ace3ccf077daa76874776bbff3_RackMultipart20200925981331hke-f4c3b51a-0edc-406a-98e4-fda92c3dfaaf-992885797.png1601026795
Changes applied:
Image_ images_messages_5f91c48d135b77e247ae3d6a_88f5258e7ac840634eff8877a69dfed5_RackMultipart2020092598084sjzx-84752ea6-9eb8-4efd-987b-02755f71bed3-835448812.png1601026858
Same Issue on NPS:
Image_ images_messages_5f91c48d135b77e247ae3d6a_40bdfa74d8f26f876247174561aca36e_RackMultipart20200925111494jvd-eb78a510-c9bb-4083-a836-48ad83512f83-170875645.png1601026893
Please open a support case from the below link and support team will help you to check the issue further.
https://support.ruckuswireless.com/cases/new
Syamantak Omer
Syamantak Omer
stephen_johanns
Error was fixed by changing the Condition on the Connection Request Policy to Day and Time Restrictions (allow all)
Good to know that issue has been fixed!
Syamantak Omer
Syamantak Omer
