05-23-2023 08:32 AM
says kernel image not found
05-23-2023 06:21 PM
05-23-2023 08:48 AM
Hi @corinanajera_
Hope you are doing well!!!
As per the case description, I could understand that you are unable to get console access to the Switch.
Could you please let me know the reason you are trying to get console access to the Switch and please the screenshot of the error you are getting?
Also please share the link of the guide you are referring to get console access.
Thank you again for your patience and understanding
05-23-2023 10:18 AM
I am trying to console the switch because it was accidentally unplugged and when I plugged it back in there are 2 lights on the switch that are on (PWR - Green and SYST - orange). However the Access Points are not on at all.
Here is the error message
NAND read: device 0 offset 0x4000000, size 0x2000000
6 ecc_errors after reading 58b8000:58b9800
iproc_nand_read_page returned 2
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
ERROR: can't get kernel image!
could not boot from secondary, no valid image; trying to boot from primary
device 0 offset 0x0, size 0xc0000
BOOTING image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
4 ecc_errors after reading 18b8000:18b9800
NAND read from offset 0 failed -22
0 bytes read: ERROR
ICX7150-Boot>%
Here is the link I was given:
FYI - I am using a MAC computer
05-23-2023 11:14 AM
Hi @corinanajera_
As you mentioned there are lights on PWR and SYST, If there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
05-23-2023 11:46 AM
for the software recovery link, where do the instructions start for MAC users? Please advise
