01-17-2023 12:48 PM
I just got a new ICX7150-c12p for replacement. I have three access points. After plugged in with the new switch, I can see that there are three recover.me wireless and one configure.me, and all access points are blinking green on 5G and 2.4G without other light on. Since this is first time I am doing this, is there a step by step guide on how to set up in order to get them to work?
01-20-2023 01:17 PM
this is what i got after reboot
01-20-2023 01:39 PM
Hi @tanchen75
Hope you are doing well !
Please make sure the cable from the Router ( Local ) ISP to the Switch is well plugged in 1 of the 12 ports available, as shown in following example:
Best Regards
Fernando Vasquez
01-20-2023 05:41 PM
Hi, Fernando
The problem has been resolved. It looks like a problem with the cable.
Thank you very much.
Tan.
01-23-2023 11:38 AM
Hi @tanchen75
Thanks for the Upgrade, and we are glad that the issues have been fixed, Please feel free to mark the post as ACCEPTED SOLUTIONS.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community Moderator
