01-17-2023 12:48 PM
I just got a new ICX7150-c12p for replacement. I have three access points. After plugged in with the new switch, I can see that there are three recover.me wireless and one configure.me, and all access points are blinking green on 5G and 2.4G without other light on. Since this is first time I am doing this, is there a step by step guide on how to set up in order to get them to work?
01-17-2023 03:47 PM
Hi @tanchen75
Please make sure the cables are connected correctly the cable from the Router ( ISP ) internet provider is connected to 1 of the 12 ports (in the red section) .
Best Regards
Fernando Vasquez
01-17-2023 08:31 PM
Thanks.
The cable connections are done according to the steps outlined in the link you provided above; There are all solid green lights on status and ethernet cable connection port (I don't have permission to upload image here).
1. Access Point R510/R310 ( AP 😞 Power light is blinking, solid green light on "CTL" and no other light.
2. there are different wireless: 3 recover.me-xxxx ( i have 3 APs) , a few of configure.m-xxxx and ruckus-unleased.
please let me know what to do next.
01-18-2023 05:04 AM
Hi @tanchen75
Based on your description, PWR LED blinking Green means that the Access Points are not getting an IP address from router. Please confirm the cable connection of your device.
Check if the port the AP is connected to is providing DHCP services on the Native/Default VLAN.
The versions must match for the AP to join the network unleashed existing
1-Connect the AP to your router to get a valid IP
2-Ssh to the IP, default credentials are admin/sp-admin
3-Run the following command > show version
4-Confirm the version of the AP
Also let me add more detail to understand the LED lights of your Access points.
R510 LED lights
01-18-2023 07:19 AM
Thanks.
For the steps outlined above 1~4, could you give me a little more details about which tools I could use to run step 2 to 4?
