changing the wireless network on the RUCKUS device for Smart Home set up
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-30-2022 05:35 PM
We would like to find out how we can change our wireless network information for out RUCKUS device, which runs our Amazon Smart Home devices. We changed internet service providers and no longer use the router we had when the system was set up. We recently had a new modem/router installed and it was suggested that the RUCKUS device be set up under the same network information as our new home wireless network. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-01-2022 04:19 AM
Hi @AD
Hope you are doing well !
If you want to make sure the connections are accurate here is short guide that can help you with this :
If you already know the login credentials ' admin / password ' using the mobile app or web for the unleashed management dashboard.
youtube.com/watch?v=L_oAReVK1qo
https://docs.ruckuswireless.com/unleashed/200.1.9.12/t-CustomizeYourWLANs.html
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
If you don't know the old credentials at all or you have no idea, we could do a Factory reset to one of the Access Points ( white box on the ceiling ) and configure from 0 for this I recommend reading the following guide carefully.
Ruckus Unleashed Set-up using your Mobile
Best Regards
Fernando Vasquez
