07-02-2024 06:40 PM
Ports not powered after outage
07-03-2024 06:41 AM
Hello @pmorales ,
From the case description, I understand that the Access points or the extenders are not powering up after the power outage.
Also, from the picture you shared, the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
Please follow the process as explained in the article and let me know if you have any queries in this regard.
07-03-2024 09:13 AM
This is beyond frustrating!!! I've tried resetting 15 times still won't work. I've tried software recovery and still won't work. Is it possible the switch is bad and I need to purchase another one?
07-03-2024 09:29 AM
Hello @pmorales ,
I really apologize for the inconvenience caused.
I understand that the ethernet port is different from that of the Switch.
If the laptop does not have an Ethernet port, kindly use an external dock connector that includes various ports, ensuring it has an RJ45 port.
Connect the external dock to the laptop.
Please make sure that both the cables is must during the software recovery process.
Also, could you please update at which point you are getting stuck and please share a screenshot for the same.
07-03-2024 09:55 AM
1. downloaded putty:
which one do i pick
2. download repository
3. download this link: https://github.com/peacepenguin/tftpd64/releases
and got this page:
