01-02-2023 06:18 AM
I have AT&T internet with 1 Gigabit data rate connected to the Ruckus R510. Would it be worth the money to upgrade to a new router with 2 Gigabit data rate? Would I see a big increase in the 5 Ghz wireless data flow?
Thanks.
Michael
01-02-2023 10:38 AM
Hi @MichaelH
For the R510 and ICX7150 Switch the max port negotiation will be 1G, if are connected to a Router that can negotiate to more than 1G, they will only pass a maximum of 1G if data, also take into consideration that one thing is the port speed negotiation and the other is the speed of your internet.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
01-05-2023 01:33 PM
Thanks. I will wait to buy the hardware until I know I can get the license,
M
01-05-2023 02:27 PM
Hi @MichaelH
Thanks for your patience.
Yarenis Hernández.
01-10-2023 10:25 AM
Any updates on obtaining a license?
01-10-2023 12:06 PM
Hi @MichaelH
Hope you are doing well
I'll be checking this request but I was looking at some resellers and they go up to $750.
Best Regards
Fernando Vasquez
01-10-2023 12:44 PM
$750 for a license to run up to 10 MBPS on an existing switch? Hm. Not sure about spending that kind of money on a two-year-old switch. I can buy a brand new ASUS AX6000 which will give me up to 6 MBPS for $270. I think I'll wait to see what the new AT&T Arris modem provides in coverage. My house is only about 1,800 square feet, so I may not need anything else, or maybe an AT&T provided extender.
