11-19-2023 08:14 AM
The lights went off and on then the access point did not work. I unplugged internet and back in then unplugged switch box and back in. Lights on front of access point were green but the back had an orange light flashing. Unplugged the cable from access point to switch but now the thermostat is going off and in line and Alexa will not play and phones will not connect What do I need to do Thank you
01-06-2024 01:59 PM
Yes it is a lennar home. I have frontier internet and ruckus box with access points
01-08-2024 06:17 AM
Hi @Nbirdwell
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
