12-03-2018 10:35 PM
08-04-2023 05:39 AM
It seems this continues to be an issue for the r510's installed in Lennar Homes. Mine will be functioning fine and then the 5G will just stop working on one of the WAP's. The light turns orange, everything connected to it struggles to reconnect to the other.
These are hardwired to the router and hardwired to power so it isn't an issue with Power or Connection. It's an issue with the r510 itself. I have patched them so they are running the latest Ruckus code. In the end, this will ONLY be fixed by Ruckus. Ruckus, you going to do anything about it because it's clearly a problem.
08-04-2023 08:52 AM
Hi @Nstars07
Hope you are doing well.
As this case is raised by @gabrielle_grow which is very old and a closed case.
To avoid confusion with posts, you can create your own post with the problem you're facing and the above mentioned description of the network issue and what you've done so that we can guide you properly.
08-24-2023 05:08 AM
I looked for this on various websites including youtube and solved it using to turn on the auto-join setting for your Wi-Fi.
08-24-2023 08:20 AM
Hi @Wordy068
Greetings of the day!!!
We appreciate for taking the time to response here and helping with the resolution that worked for you.
Feel free to contact us on the RUCKUS Lennar Home Community forum for future queries.
Thank you again.
