12-08-2025 07:02 AM
12-08-2025 07:34 AM
Hi @ankitpat86 ,
As per the case description, I understand that your Ruckus Access points are not working.
1. Was there any power outage before you started facing this issue?
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
12-12-2025 06:36 AM
Hello @ankitpat86 ,
12-15-2025 07:24 AM
Hello @ankitpat86 ,
12-17-2025 06:33 AM
Hi @ankitpat86 ,
Thank you.
