Wi-Fi ICX-7150 C12 running slow after power outage
Wzz
Wi-Fi ICX-7150 C12 running slow after power outage. But still able to connect to my devices. And I try to login Ruckus IP page with all the combinations of user name and password. None of these are working. How can I resolve this issue?
1 ACCEPTED SOLUTION
Imran_ruckus
Community Manager
Community Manager
Hi @Wzz
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
VIDEO LINK AS REFERENCEhttps://www.youtube.com/watch?v=Eem1IBgYaWc
We suggest upgrading your switch to the latest stable version to avoid this issue in the future. Your Switch is on a older version that is 08080d. Please let us know once you complete the above process to assist you with the Upgrade of the Switch.
7 REPLIES 7
Imran_ruckus
Community Manager
Community Manager
Hi @Wzz
Great!!! Good to know that your Switch is now working as expected.
Yes, to avoid this issue in the future we always recommend you Upgrading your Switch to the recommended stable version.
Please confirm, I will share the guide to Upgrade and you can proceed at your convenience.
If you are stuck at any point please take screenshots and share and I will continue assisting you on MONDAY as I am almost out of my shift hours.
Please confirm and let me know if you have any queries in this regard.
Yes please!
Imran_ruckus
Community Manager
Community Manager
Hi @Wzz
Thank you for the response and the confirmation.
Please follow to the below steps explaining the Upgrade process.
The recommended stable versions is 8095g (08.0.95g)
The Upgrade path would be: 08080d (your current version)>>8080f>>8095g
(PLEASE NOTE: Use 08095g patch in place of 8095h as explained in the guide)
Your Upgrade folder should contain these 3 files shown in the below screenshot: (Refer the guide link for more information)
Below are the options or methods to perform the Upgrade on the switch: You could choose any one of these.
1st Option:
1. In this option, we will use a pen drive or USB flash drive in which we move the files to the pen drive and connect it to the Switch then through CLI we execute the commands to upgrade the Switch using the following guide as a reference:
2nd Option:
2. The following guide is an example of an upgrade via TFTP server, by using an application (FREE) to send files or upload remote files to a device, in our case, we will use it to update a new version to the Switch, basically it will send the image version remotely from the computer to the switch.
3rd Option:
3. In this option we Upgrade the Switch from the Web Interface (GUI) of switch.
https://0.0.0.0 or http://0.0.0.0 (IP address of Switch. 0.0.0.0 is just as an example)
As you can access CLI, I would suggest you follow the 2nd option.
