โ04-17-2023 02:01 PM
Good afternoon,
Please note, I am not an IT expert...I probably wouldn't even call myself a novice.
I recently updated my router to the Eero's at the suggestion of my internet provider because I was having issues with the Ruckus staying connected to the last two routers I purchased (Nighthawk and Rapture GT-AX11000 - which are both great routers). My signal is now very weak and most devices won't connect to the internet, if they connect, the buffer or drop constantly. Hotspot is our best friend at the moment. Two of the three Eero's will connect but the third says it is too far away from the main one, but the room is directly below the other, so this makes no sense to me. I reset my modem a while back and it was stuck in Recover-me mode for several months, I somehow got it out of that, but since then, it has not worked the same or well with any router.
Second issue - I cannot log in to the Unleashed app (I don't remember the password) and it will not allow me to reset the password because it states it is disabled. So assistance with this would help also.
Thirds - Is there someone that I can call to help me with my connectivity issues through the Lennar community or go with an outside IT person if problems persist since I truly do not know what I am doing and probably cause more harm than good when I try to "fix" the problems.
โ04-17-2023 02:41 PM
Hi @mraybellwick
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and the connectivity is unstable.
I truly apologize for the inconvenience.
Effective Novemberโ2022, โRuckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model only.
Please do not worry, we have tried to create the guides as non-technical as possible so that they are not much difficult to follow.
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same)
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights. Also, light the status of Access Points.
Please let us know the answers to the above queries or if you have any queries in this regard.
Thank you again for your patience and understanding
Lennar Home Community.
โ04-18-2023 08:25 AM
โ04-18-2023 12:04 PM
Hi @mraybellwick
The lights status of the Switch and APs are in normal condition.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a โRouting Codeโ results in causing this issue. To check the same please follow the below process.
1. To check this issue, we must identify the โcurrentโ IP address assigned by your local router to the switch ICX-7150-C12P
How to find my Ruckus โDevices IP addressโ using free applications:
2. Once we identify the IP address of the switch proceed to access remotely to the device โCommand Lineโ
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
โ04-18-2023 12:55 PM
I only have two Ruckus Wireless items and neither are the IXC, the unlabeled items do not open or are blocked. It has been running at 99% for over 5 minutes now.
