02-25-2025 12:23 PM
Just recently got time to work on upgrading my switch as I've been upgrading my Lennar-provided APs over time but never had the switch show up in the Unleashed app.
I tried to use the Upgrade Tool to perform the upgrade, but I get the error message "Unable to Upload Upgrade Image to Primary Partition".
Here is my show version from the console:
show version
Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
UNIT 1: compiled on Nov 20 2018 at 00:09:55 labeled as SPS08080d
(25968884 bytes) from Secondary SPS08080d.bin
SW: Version 08.0.80dT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114)
Compiled on Thu Nov 15 12:59:22 2018
HW: Stackable ICX7150-C12-POE
Serial #:FEK3820R2GF
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
--More--, next page: Space, next line: Return key, quit: Control-c
STACKID 1 system uptime is 10 minute(s) 40 second(s)
The system started at 00:22:11 GMT+00 Sat Jan 01 2000
The system : started=warm start reloaded=by "reload"
...and here is my show flash:
show flash
Stack unit 1:
Compressed Pri Code size = 25968884, Version:08.0.80dT211 (SPS08080d.bin)
Compressed Sec Code size = 25968884, Version:08.0.80dT211 (SPS08080d.bin)
Code Flash Free Space = 1204994048
Can you assist?
Thank you in advance!
02-26-2025 05:14 AM
Hello @georgia4 ,
As per the case description, I understand that you have upgraded the Switch to the latest version.
Also, you tried to access the Switch through GUI, and you are unable to login with the login credentials.
We do not need any login credentials to access CLI using the Telnet option. If Telnet is enabled on the Switch it can be accessed directly using an IP Address of the Switch.
FIGURE 3 Accessing CLI using the Telnet option
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Once you are able to access the CLI, I would request you to please execute the following commands to reset the Switch login credentials.
ICX7150-12P Switch>enable
ICX7150-12P Switch#configure terminal
ICX7150-12P Switch# username super password pass
Where the username is ’super’ and password ‘pass’ (You could choose any of your choices)
To allow the correct authentication please run the following commands:
ICX7150-12P Switch (config)#crypto key generate rsa
ICX7150-12P Switch (config)# aaa authentication login default local
ICX7150-12P Switch (config)# aaa authentication web-server default local
Please share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
02-28-2025 09:39 AM
Hi Pinky,
I got it all worked out! Thank you so much for your help. I am now on 08095g.
Now I just have to figure out why I have dropped connections :(. Is there a troubleshooting guide that helps determine if it's an issue with my APs, switch, or modem?
02-28-2025 11:00 AM
Hello @georgia4 ,
We are glad that you were able to upgrade the Switch version and could login to the GUI of the Switch and reset the password.
You may have faced issues while the Switch was in the older version, and now it is in the recommended version.
Please do not hesitate to contact us if you face any issues with your Ruckus network.
03-03-2025 07:53 AM
Hello @georgia4 ,
03-05-2025 06:02 AM
Hello @georgia4 ,
03-05-2025 06:11 AM
Hi Pinky,
Apologies for the delay. Everything is working fine now. THANK YOU for your help. I am having fewer outages on the APs, so you can close this issue.
