Switch stuck in router mode
Cg44150
Icx7150 switch stuck in router mode. Will not connect access ports. Need a replacement.
14 REPLIES 14
Imran_ruckus
Community Manager
Community Manager
Hi @Cg44150
As per the case description, I understand that your RUCKUS Switch is stuck on Routing code mode.
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
Yes it worked before. Yes there were power outages/serges. The isp connection is fine and works without ruckus system. I have 3 access points connected. Will send pictures as well.
Hi @Cg44150
Could you please share the pictures as well?
